Page 6 of 6 FirstFirst ... 456
Results 51 to 55 of 55
Thread: '96 VR6 - Auto to Manual [Build]
  1. #51
    Nov 2014
    Quote Originally Posted by stephen8512 View Post
    wow...big difference. Did you go for the OEM one or did you upgrade to a billet item
    I just went for another OEM one.
  2. #52
    Nov 2014
    Have had a long break, I'm now back am back at it over summer.
    I had a terrible time trying to get the axles out of the hubs. Had the specialty tool which clamps via the wheel bolts and drives the a bolt through the centre to push the axle out. Long story short, it didn't work. Decided to remove the whole assembly instead.
    The brake pads were a bit tight removing them. Is there any way to open the callipers up a little? I imagine the others will be a tight fit.
    I replaced the water pump as well as a precautionary measure.
    New vs. Old:
    Now I'm going to start pulling out the manual gear from the donor car. Does anyone know of some good diagrams for the vacuum hoses? I've had a few snap and want to re-run the lines.
    Thanks! Happy to be active again!
  3. #53
    Nov 2014
    Removing the manual transmission:
    Removing the driver side axle:
    It was a long reach:
    Pulled out through the passenger wheel well:
    After a thorough clean:
    The clutch:
    Flywheel:
  4. #54
    Nov 2014
    I'm wondering if the flywheel/clutch are suitable to re-use? It was allegedly installed <1000km's ago and from my knowledge it all looks to be in great condition. Are there any red flags to look for?
    Thanks
    edit:
    A profile photo of the clutch:
  5. #55
    Nov 2014
    So I've been slowly chipping away getting bits and pieces done.
    It's gone off to Volkwerke to have a once over and see what else needs to be done. Hopefully it's nothing too painful.
